10-14-2021 16:33 - last edited on 10-15-2021 08:07 by LiliyaFitbit
Hello everyone, I’ve experienced an issue that has me a bit concerned that I have a faulty device. I purchased my Charge 5 a week ago and ever since then I’ve religiously worn the thing to bed. Sleep score sounds like a neat feature that I want more data from. However in these 8 days, I’ve only gotten 2 nights where I get a sleep score.
now my understanding is that I should get a sleep score for each night along with the Time Asleep, Deep and REM, and Restoration breakdowns. But I guess these are also associated with the sleep score.
At this point, I’ve adjusted the Change to be tighter, looser, restarted the devise, played with the syncing, and also updated the sensitivity from Normal to sensitive. Are there any other things I can attempt to do in order to get this information? Or do I have a dud?
I’d appreciate any and all advise here. Thank you.
06-02-2022 05:53
06-02-2022 05:53
06-02-2022 06:24
06-02-2022 06:24
Best Answer06-02-2022 07:10
06-02-2022 07:10
No it didn’t, but maybe I packed it up too soon to return it. They are sending me a replacement because it is within the 45 day return time. I will give it one more chance.
Best Answer06-02-2022 09:34
06-02-2022 09:34
No, yours is not the only dud. I’ve had the same problem with charge 5. I’ve done everything fit suggested, it’s never worked consistently- now doesn’t log it at all. I’ve talked to support department 3 times in the last 2 weeks trying to get a replacement. Each time a representative assured me I would get an email with instructions on how to get a new one - they have never sent me any type answer, -0- emails! My charge 5 does not work & obviously Fitbit knows and doesn’t care. I’m done messing with them, I’ll throw mine in the trash & buy a different brand
06-02-2022 14:20
06-02-2022 14:20
06-09-2022
11:49
08:40
06-09-2022
11:49
08:40
Hi everyone, I appreciate all the updates that you've shared so far about this issue with your sleep score. I'm sorry to see that some of you are still having this problem, but it's good to know that some users have also stared to received sleep score information again.
If you're new to this thread, please make sure that you've exhausted all the troubleshooting options mentioned here earlier. If you continue to have the same problem after all the steps shared in the forums, please keep in mind that it will be necessary to continue the communication with the Customer Support team so they can provide you with the next steps.
You can click here to chat with us online or give us a call. Keep in mind that it may take a bit longer to receive a response if you're case has been escalated to a different department, please keep an eye on your inbox.
Thanks again for all the information provided. The team continues to work to improve the Fitbit experience and your feedback is a big part of that process.
Best Answer06-10-2022 02:44
06-10-2022 02:44
Best Answer06-10-2022 03:51
06-10-2022 03:51
Best Answer06-10-2022 07:01
06-10-2022 07:01
Best Answer06-12-2022 04:47
06-12-2022 04:47
07-10-2022 12:10
07-10-2022 12:10
Joining the group... Had a charge 3 for a long while, sleep score worked fine mostly. Upgraded to Charge 5, worked fine for 6 weeks. Then stopped showing sleep score ("couldn't get stable heart reading"). Everything else seemed fine, including heart rate, variability, etc. Just no detailed sleep stages or score. Sleep score came back for a few days then went. Seemingly random.
Go to support a bunch of times, jumped through all the hoops -- rebooted, reset, logged out, logged in, turned things off and back on... Nothing. Seems to be either faulty hardware or just not very reliable. Support not super-helpful other than to read from the manual about how to do the handful of things that "often" resolve this.
The sleep score was #1 reason to buy fitbit vs alternatives.
Best Answer07-10-2022 12:18
07-10-2022 12:18
Best Answer07-10-2022 12:44
07-10-2022 12:44
Currently I’m not complaining because the sleep score is miraculously working on 33/35 past days. After a horrendous month of May when it rarely worked, all of a sudden it was fixed. I didn’t do anything different - it just started working. Go figure!
Best Answer07-10-2022 13:05
07-10-2022 13:05
Best Answer07-10-2022 13:11
07-10-2022 13:11
Best Answer07-10-2022 15:57
07-10-2022 15:57
Best Answer07-11-2022 03:46
07-11-2022 03:46
Best Answer07-11-2022 05:47
07-11-2022 05:47
I have experienced problems with the sleep and heath metrics ever since I acquired my 5. Fitbit replaced it once, with no effect. In conjunction with support, I tried all the various suggestions, device restarts, changing positions on the wrist or even the dominant wrist, clock face, etc. Finally they suggested a factory reset, which we did and they asked to monitor for several days and get back to them. The results were still inconsistent. I reported this and was told support was going to escalate and I should receive an email response in a few hours. That was a few days ago
07-16-2022 09:13
07-16-2022 09:13
Liliya, I contacted Chat about this same problem yesterday and they told me to change my sleep setting to "sensitive", the opposite of what you're advising. Now I'm really confused! (and also, it didn't help--I still don't get sleep stages, only awake/restless/asleep).
Best Answer07-16-2022 09:24 - edited 07-16-2022 09:25
They did the same to me (had me change to sensitive) but it makes no sense. All it did was record my sleep pattern (sleep/awake/restless) in smaller details (which is logical, for sensitivity increase). Still no sleep score. I turned it back.
I strongly suspect this is a major flaw in Charge 5 and Fitbit have no idea what is causing the problem. I would advise anyone shopping to avoid charge 5.
