03-01-2024 04:35
03-01-2024 04:35
I'm not sure what happened but my Charge 5 was working fine and now it's going through it's battery life at like 5% per hour. Prior to this I had a week of battery life consistently.ive had no updates or changes to settings.
Any fix to this or is this just the beginning of the end?
03-01-2024 09:40
03-01-2024 09:40
Hi, @buccy, welcome to the community, it depends on how long you've had it. Over 2 years? It might be a bad sign, but you might like to check out why my Fitbit device's battery is not charging. - Fitbit Help Center If less than two years look at What's Fitbit's return and warranty policy? - Fitbit Help Center. If you think you have the benefit of the warranty contact "Customer Support".
I hope this heps.
Cheers
Gr4ndp4 | UK
03-02-2024 06:48
03-02-2024 06:48
Same problem here. Starten last week. Bad firmware update?
03-02-2024 07:11
03-02-2024 07:11
Hi, @SunsetRunner, welcome to the community, have you followed the advice in my earlier post?
Let us know how you get on.
Cheers
Gr4ndp4 | UK
03-02-2024 07:23
03-02-2024 07:23
Hello. I looked at the page. But problem is not the charging, but the draining of the battery. Before, 1 week, now not even 1 day.
03-02-2024 08:10
03-02-2024 08:10
Hi, @SunsetRunner , thanks for the feedback, have you been using GPS set on built-in, this is a well-known juice guzzler How do I use GPS on my Fitbit device? - Fitbit Help Center My advice is to use the phone's GPS, a much larger battery & antenna. If you have "Snore report" working this will also drain the battery as the microphone is on all night. How do I track my sleep with my Fitbit device? - Fitbit Help Center explains.
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
Best Answer03-02-2024 08:26 - edited 03-02-2024 09:48
Gps is Mobile. Found post about firmware. Looks like I am one of the persons with a useless product after 14 months of good product killed by firmware upgrade after “google service”. Will call customer support on monday,
unfortunatyy I now really need a heartrate monitor because I was in hospital 4 weeks ago with heart attack. Is that not ironic?
