12-28-2021 12:23
12-28-2021 12:23
Hello!
was wondering if there was a way to track step that are taken during a bike ride without pausing (if that makes sense)
thank you
Best Answer12-28-2021 15:41
12-28-2021 15:41
Hello @Jafinc
I'm not really sure what you mean. You wouldn't be taking steps on a bike as such.
You could set up Bike as an Exercise Shortcut on the App on your phone:
Tap your profile picture on the Today page, then Charge 5, then Exercise Shortcuts. Remove one you don't use by swiping left, then tap on +Exercise Shortcut to add it, then sync your Charge 5, so it shows up under exercise.
Then, when you start your bike ride, you could go to the shortcut on your Charge 5 and tap Start and when you finish Finish. That would record it as exercise in the App.
I hope that helps a bit. If it wasn't what you were looking for, please try to give some more detail as it will make it easier for people to help you.
