08-26-2023
16:24
04:53
08-26-2023
16:24
04:53
I have a Fitbit Charge 5 which I wear on my left wrist (non-dominant). I became another statistic recently when I stumbled playing Pickleball outdoors, on cement. I fell backwards and my left arm slammed to the ground. I broke two bones in my wrist and and have been in a cast. What’s so amazing is that there was absolutely no damage to my Fitbit and it still works. I had to move it to my right wrist and the only negative is that it needs to be charged every 3 days and it’s impossible to put in on by myself with only, one hand…
08-27-2023 04:57
08-27-2023 04:57
Hello there, @Sharoncs. Thanks for stopping by in the Fitbit Community Forums. I'm really sorry to hear about your accident, thankfully you're ok. I wish you a good and smooth recovery, patience is key. Take good care of you during this time!
Thanks for also sharing that there was no damage to your Charge 5. 🙂
Regarding the battery short life, in general, it is recommended to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. This should also help with the problem you mentioned with the display:
