08-13-2022
07:17
07:18
DavideFitbit
08-13-2022
07:17
07:18
DavideFitbit
my Fitbit stoped tracking data after the new update i also got some wierd red x that showed up and some point is it dead and do i need to get a new one also the HR sensor is only flashing red
07:18
04:23
08-16-2022
07:18
04:23
Hi, welcome back to the Community forums, @pineapple69.
Thank you for all the information that you've shared about this issue with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method described here below:
In addition to the restart, you can also try setting up the Charge 5 as a new device in your account.
Hope this helps, I'll be around.
Best Answerhi i tried both those things and it didint fix the problem
06:17
04:21
09-09-2022
06:17
04:21
@pineapple69 Thank you for your reply and for confirming that you continue to experience the same problem after the troubleshooting steps suggested.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
See you around.
