06-24-2023
05:51
04:15
06-24-2023
05:51
04:15
Me as well. My charge 5 for the last two days hasn't shown either sleep score or BPM. I've done everything under the sun, and still this morning nothing.
Best Answer06-24-2023 03:33
06-24-2023 10:48
06-24-2023 10:48
Same here. One night it works then it doesn’t. Also never has the correct time I sleep. Does any of the trackers work correctly re sleep?
Best Answer06-25-2023 04:20 - edited 06-25-2023 04:20
Hi there, @Steelergurl64 @Walker1818 @lilosmith. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Fitbit devices before reaching out.
I'd recommend trying the following steps to make sure your heart rate is working:
Bear in mind that if your heart rate is not working, your sleep stages won't too as this data is calculated by your heart rate readings. With that in mind, I'd suggest taking a look at this help article Why don't I see sleep stages today?
Best Answer06-28-2023 10:05
06-28-2023 10:05
I have this same issue, for both heart rate and steps. I’ve tried every suggestion on this forum but nothing helps. It stopped around noon (Central European Time) today. It looks like the sensor lights are off.
Best Answer06-28-2023 11:00
06-28-2023 11:00
