10-13-2023
19:34
16:57
10-13-2023
19:34
16:57
My Charge 5 has stopped displaying my heart rate. It tracks my steps but not my heart rate. It just suddenly stopped.
10-14-2023 12:03
10-14-2023 12:03
Hello @BillSul
Do you see a green light in the back of your Charge 5? You can try running your finger across the sensors in the back a few times to see if the green light shows. If you don't see a green light, then that's likely the issue.
I'm not positive if restarting the device will get your Charge 5 "unstuck" and back to tracking your heart rate. It's something you can try. You can restart your Fitbit from the Setting menu on the device or use the charging cable that came with your device. If you would like instructions, click on: How to restart the Charge 5
If this is not successful, you probably should contact Fitbit support (<-- click link)
Best Answer10-14-2023 17:01 - edited 10-14-2023 17:02
Hello there, @BillSul. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
As a first approach, please follow the tips and recommendations provided by @RiekoC. If the issue persists, please try the following steps to reset your heart rate settings:
Best Answer10-14-2023 18:28
10-14-2023 18:28
Best Answer10-15-2023 11:16
10-15-2023 11:16
Hi @BillSul
Thanks for letting us know that you're seeing your heart rate again. Glad to know that a restart fixed the issue.
