06-12-2024
11:46
04:37
06-12-2024
11:46
04:37
My charge 5 won't show my pulse. I've restarted but it did not help. What shall I do?
06-12-2024 13:19 - edited 06-12-2024 13:20
Hello @MatsOljelund
Do you see a green light on the back of your Charge 5? The green light is your heart rate sensor. You can check by placing your finger across the back. The green light should show when you lift your finger.
If you don't see the green light, the first thing to check is if Heart rate somehow got turned off on your Charge 5:
If heart rate was on, but you still don't see the green light, try restarting your Charge 5 again. You might want to try doing the restart a few times as I've seen several users mention that they had to do multiple restarts.
If you still don't see the green light and depending on when you got your Charge 5, you could contact Fitbit support (<-- click link). Most likely, they will have you repeat some of the troubleshooting steps you've already done. If they confirm that your device is defective and it's still under warranty, they should let you know what are your options under warranty.
I have seen some users report that Support had them do a factory reset, which restored their heart rate sensor. If you want to give this a try before contacting Support, make sure to do a sync first. Doing a factory reset will erase all the tracked data on your Charge 5. This help page has the instructions on how to erase your Fitbit (aka factory reset) (<-- click link). After you complete the factory reset, set up the Charge 5 as a new device in the Fitbit app.
06-12-2024 13:26
06-12-2024 13:26
I can see the green light. Its a steady green light.
06-12-2024 13:55
06-12-2024 13:55
Hello @MatsOljelund
Thanks for followup and letting us know that you see the green light. That's great news since that means your heart rate sensor is on.
At this point, I suggest doing at least 1 more restart to see if that will get your Charge 5 back to tracking your heart rate.
Best Answer06-12-2024 14:11
06-12-2024 14:11
I've tried restarting but with no result. Still no pulse registration...
Best Answer06-13-2024 12:56
06-13-2024 12:56
Hello @MatsOljelund
Thank you for letting us know that restarting didn't resolve the problem with seeing your heart rate.
At this point, you probably should call Fitbit support or try doing a factory reset.
