07-15-2024
03:04
03:13
07-15-2024
03:04
03:13
Dear All,
My Fitbit Charge5 stopped detecting my heartbeat.
I tried to restart it more times but it dors not work.
I also switched OFF and ON the heartbeat detection in the SETTINGS, but with no results.
furthermore, I noted that the LEDs are off
How cai I solve the problem?
Thank you
Antonio
07-15-2024 03:17
07-15-2024 03:17
Hi there, @AntonioF. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still not tracking your heart rate. I understand how annoying this can be, I will do my best to help you with this!
As our last resort, I'd suggest performing a factory reset. IMPORTANT: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Charge 5 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that How do I set up my Fit-bit device?
Best Answer07-15-2024 03:37
07-15-2024 03:37
Dear MarreFitbit, thank you for your prompt reply.
Before performing a factory reset as you suggested, I would ask you if you considered the fact that the green LEDs of my Charge 5 are OFF while, before this problem, they were usually ON.
Thank you,
Antonio
Best Answer07-15-2024 04:36
07-15-2024 04:36
@AntonioF Thanks to you for getting back to me.
Regarding your questions, yes, I considered the fact that the LEDs are not working on your Charge 5.
Best Answer07-15-2024 09:13
07-15-2024 09:13
I did all the steps you outlined above but the heart rate is not tracking and the LED lights are not flashing
07-16-2024 13:48
07-16-2024 13:48
Hello @MarilynZC
I've seen some users report that they did an additional factory reset as directed by Support, after trying that prior to contacting Support, and that it worked to restore their heart rate sensor (green light on the back).
You might want to try repeating the factory reset to see if that will work to restore your heart rate sensor.
Best Answer07-17-2024 03:03
07-17-2024 03:03
Most of the time I can only solve this with a restart of the Charge 5.
See also Charge 5 stops Monitoring Heartbeat
But why it stops????
And can it be solved?
Best Answer07-30-2024 06:20
07-30-2024 06:20
Hi,
After many restarts, at the end I did a factory reset as you suggested and it seems that heart rate is working (even if some times I have to restart the Charge 5 because the LED lights are not flashing and the heart rate is not detected).
Another problem I noted after all the restarts and the factory reset is that - NOW - the battery life of my Fitbit Charge 5 is very limited.
For example: 99% at 12:48; 80% at 15:05; 77% at 15:17
Do you have any suggestions?
Thank you
Antonio
Best Answer07-30-2024 11:10
07-30-2024 11:10
Hello @AntonioF
Glad to see that you were able to get the heart rate sensor working again.
Regarding the rapid drop in battery: When my Charge 5 started having rapid battery loss, I restarted and recharged my device multiple times over several days. As soon as I noticed the excessive drop, I restarted my Charge 5 and put it on the charger until it was back at 100%, often doing this several times a day. Eventually, this process got my Charge 5 "unstuck" and the battery went back to lasting 6-7 days. There's no guarantee that this will work for you, but it might be worth a try.
Best Answer08-01-2024 01:58
