12-12-2024
19:03
09:08
12-12-2024
19:03
09:08
I'm not getting any sleep data. Where do I start to troubleshoot?
Hi there, @ritabel. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I will do my best to help you with this!
While reading your post, I was wondering if your Charge 5 is still tracking your heart rate? If your heart rate is OFF, you won't get sleep stages as heart rate readings are key for your sleep details. With that being said, I'd recommend trying the following steps to make sure your heart rate is working:
In addition to that, I suggest taking a look at this help article Why don't I see sleep stages today?
Best AnswerHello @ritabel
Do you manually start & stop your sleep session on your Charge 5? If so, that is likely the reason why you're not seeing sleep data. You need to let the Charge 5 recognize when you start your sleep & when you wake up to track & record your sleep data.
It's also helpful to set up a bedtime schedule, if you haven't already done so.
