12-06-2023
14:37
04:52
12-06-2023
14:37
04:52
I’m so disappointed, my Charge 5 stopped working within 8 months of purchase. I would shower with it, so maybe it’s not water proof. What a waste of money, no warranty too.
12-07-2023 03:33 - edited 12-07-2023 03:34
Welcome to the Fitbit community, @loidablackle!
Sad to hear that your Charge 5 isn't working as expected.
As a first approach to hopefully get things fixed, I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt, please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
If that really won't work for you, please try if changing your device's clock face will get it back to working order. Here's how to do that:
How do I change the clock face on my Fitbit device?
If none of that would help, I'd recommend to contact Fitbit support for further assistance as you've mentioned that you've purchased your device just 8 months ago. Fitbit's warranty period, depending on how/where you've purchased your Fitbit device, is at least is 12 months after purchase, so you should be able to get a replacement if your device really is dead. Here's ho to reach Fitbit support:
