12-18-2023
		22:54
		02:23
		12-18-2023
		22:54
		02:23
My Charge 5 worked fine for 2 years but has stopped working.  I trued all the resets options and nothing worked.  I checked the web to see the life expectancy for a Charge 5.  Apparently it is normal for a Charge 5 to fail after 2 years.  My Citizen EcoDrive is still working after 20 years!!  Fitbit has apparently built in obsolescence/failure.  In view of the mountains of electronic waste around the world this is completely unacceptable and as they are apparently unrepairable, even more so.  Inwill not be buying any more of these throw away gimmicks.
12-19-2023 02:33
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              12-19-2023 02:33
Hi there, @marsrogj. Welcome to the Fitbit Community Forums. It's sad to hear that your Charge 5 is still not responding despite all the steps you've tried. I understand where your concern is coming from and how you must be feeling as your Fitbit device is only two years old. We‘re taking your comments and sentiments in regards to our products into consideration.
Please note that our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy  is set into providing as much coverage as we can. For more information about our warranty, see fitbit.com/legal/returns-and-warranty
I'll be more than glad to help you with your Charge 5. In order to do so, may I know more details about the issue with your device? Is it not charging? syncing? Also, please let me know all the steps you've tried so far so I don't provide the same ones.
Looking forward to hearing from you.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer12-19-2023 14:36
12-19-2023 14:36
It charged but the battery died after roughly 12 hours. So either the battery is dead or there is a fault which drains the battery.
 Best Answer12-21-2023 03:02
                              12-21-2023 03:02
@marsrogj Thanks for getting back and the details provided in your recent post. Let's figure out what is the issue with your Charge 5's battery.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please complete a three pulse restart following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
 Best Answer12-21-2023 16:37
12-21-2023 16:37
12-22-2023 02:52
                              12-22-2023 02:52
@marsrogj Thank you so much for trying the steps I provided above.
I've created a case to get you in contact with our Support Team about this issue. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you shortly!
We hope to get you back on track soon!
