02-05-2024
02:57
03:30
02-05-2024
02:57
03:30
Fit stopped working all of a sudden
What can I do to fix this ?
Best Answer02-05-2024 03:04
02-05-2024 03:04
Hi, @Ak2116 Can you please provide more information? The usual advice is to restart your Charge 5 -
How do I restart my Fitbit device? - Fitbit Help Center provides advice & guidance. This video demonstrates the process.
Let us know by posting here again.
Cheers
Gr4ndp4 | UK
02-05-2024 03:07
02-05-2024 03:07
Thanks for the troubleshoot advice
It is working now 👍
Best Answer02-05-2024 03:09
02-05-2024 03:09
Hi, @Ak2116, Great, I'm pleased you fixed it.
Cheers
Gr4ndp4 | UK
Best Answer02-05-2024 04:46
02-05-2024 04:46
It is not working again
Black screen appeared again
Best Answer02-05-2024 05:29
02-05-2024 05:29
Hi, @Ak2116, I'm sorry to hear your problem has not gone away. Is your Charge 5 battery fully charged? Check the Fitbit app on your phone. If it is not showing charge review this article Why isn't my Fitbit device's battery charging? - Fitbit Help Center If fully discharged it will need at least 60 minutes on a live USB socket before you see any sign of life.
You might like to review this thread (even though it's more than two years old) Solved: Charge 5 screen is blacked out and won't start - Fitbit Community
I hope this helps, let us know how you get on.
Cheers
Gr4ndp4 | UK
