Charge 5 stops tracking sleep when I go to bathroom
ANSWERED
Hey all,
So.. new to Fitbit, just got a Charge5 a week or so ago. I go to the bathroom sometimes around 3 or 4 am or so. Its like 10 steps away. Last night, I had good sleep, looked at my record and it said 2.5 hours, fair. Yet, I woke up at 8:30 with the one bathroom break.
I have done this a few times and it did not stop the sleep record. Today it did. I find it odd.. I assumed that it could tell using the sensors when we were sleeping. How else does it monitor REM, etc? I am curious how the sensors under the watch are able to determine that. I am guessing it has to do with heart rate, and maybe the angle the unit is resting at?
If that is the case.. what would cause it to not work sometimes? I would assume after I went back to bed, it would pick up on my lower heart rate, and continue with the sleep record.
Even if we go down and get a drink, then come back to bed, it should pick up on the break period, and then more sleep and accumulate all that, right?
I just want to make sure there isn't a) something wrong with my unit or b) something I need to tap/do on the unit to let it know I am going back to sleep.
1 BEST ANSWER
Accepted Solutions
Welcome, @beuwolf! It's great to see you around.
Thanks for the details provided. Charge 5 and the other Fitbit devices will track your sleep automatically based on your movement, heart rate, etc. When you wake up and walk a few steps, your device will detect this movement to know that you're awake so it'll interrupt the sleep tracker. For this reason you may see a split on the sleep graph. You can check this help article for more details: How do I track my sleep with my Fitbit device?
When your body is completely at rest and you haven’t moved for about an hour, your Charge 5 records that you’re asleep. So you don't have to tap or press anything on your device to start tracking your sleep again.
On a side note, I moved your post to the Charge 5 board to keep our Community organized.
See you around.
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
5 REPLIES 5
See you around.
It just that the Charge 5 seems more sensitive to this compared to Charge 4. The 4  it was fine to just walk a few steps to bathroom and return to bed and then have one sleep stat.
It appears the split tracking problem is the lost hour of record as one returns from water or bathroom short beak and Fitbit device has to then see a new and fresh hour of stillness to re-detect sleep commencing again, so the split record is not accurate either. This has happened repeatedly for me as I awake to hit bathroom for 4 min. nightly between 2-4AM. It then provides a 65 up to 74 score due to time awake and is wholly inaccurate, split cycle aside.
I also have this problem.  If I go to the bathroom say at 5 am, and then come back to bed and sleep until 8, the tracker has only recorded my sleep until.5am and not the sleep between 5 and 8 am
Same problem and too frequently over the last week especially. I need to visit the loo twice nightly and on four occasions in the last week I’ve had two hour plus gaps on my sleep log when I know for certain I was asleep for more than half that time. It’s a bit depressing when you have sleep issues as it undermines your confidence that things are improving.
