11-04-2024
03:39
10:54
11-04-2024
03:39
10:54
I am using Charge 5 and noticing it switches off (nothings happens not even charging) when washing my hands or using in normal water conditions. In the past one month this is the third instance that this has happened.
After certain days watch again comes to life but it's frustrating. I also understand that my watch is out of warranty, but I feel water resistance should be covered by manufacturer for a much longer time, otherwise the whole purpose is defeated.
can anyone help who might faced similar issue..
Best Answer11-04-2024 11:02
11-04-2024 11:02
Hi there, @deepankar1990. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 stops working when it gets in contact with water. I understand your concern, I will do my best to help you with this!
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If your Charge 5 is unresponsive, I'd recommend trying the steps below:
Best Answer11-05-2024 00:42
11-05-2024 00:42
Hello Marre,
Thanks for the response, but what exactly do we mean by Fitbit getting wet.
I am just washing my hands and even then, this problem appears. Are we not considering the device as water resistant even to that level.
Like I said earlier if this is the case, then the whole purpose is defeated.
