11-05-2023
04:31
09:10
11-05-2023
04:31
09:10
I got fitbit charge 5 , only been using for about 11 months as got for Christmas last year. It not charging it got fitbit logoand suck on that. Not syncing to my phone won't go on. I try clean it and wipe it even try to set up again, on my phone by nothing.. I try reset via the charge but nothing stay on the fitbit logo. It been on charge all night and most of today. Any ideas. Thanks
11-05-2023 09:09
11-05-2023 09:09
Hi there, @Maddie6. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 is not responding. Thanks for taking the time to troubleshoot the issue prior to posting here, I understand where your concern is coming from. I'll be glad to continue assisting you.
In addition to the steps you've tried, please try the following steps while your Charge 5 is connected to the charging cable:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If the above doesn't work and you don't feel any vibration while performing a restart, please try the steps provided here Why isn't my Fitbit device's battery charging?
Once you make sure that your Charge 5 is charging, try the steps above one more time.
Hope that helps.
Best Answer11-05-2023 10:22
11-05-2023 10:22
I have the r act same issue and it’s frustrating. I’ve done several “different” troubleshooting that the chat and manual suggested. From pushing buttons to Taking it off Bluetooth and restarting. I’ve had several Garmins, polar and other types of watches. I’ve never experienced anything like this.
11-06-2023 05:59
11-06-2023 05:59
Mine bricked last week, ive tried everything!
Best Answer11-06-2023 13:48
11-06-2023 13:48
My fitbit stiilll under warranty. So sending back to the place I purchased it from. Being collected via courier for free. Just get a exchange.. so new on the way. Thanks for everyone who sent the information. On how to fix it. Though I did try everything. I'm just using the old charge 4 fit bit now. Till my new one comes. That still work gr8. Even though not use for pass 11month. Thanks.
Best Answer11-06-2023 13:49
11-06-2023 13:49
Thanks try everything. Not working. Still unwarranted. So get a replacement. Thanks..
Best Answer11-06-2023 13:51
11-06-2023 13:51
If under warranty. U could get Exchange. That what I done. Getting collected and sending new one out.
