06-18-2023
08:30
08:31
06-18-2023
08:30
08:31
Fit bit charge 5 shows Fitbit logo only. I have tried reinstalling app and reinstalling on phone but will not connect to phone.
Best Answer06-18-2023 08:33
06-18-2023 08:33
Hi there, @SueClemphoto. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
In addition to the steps you've done so far, I suggest following the steps below in the order listed:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
