05-04-2022
18:35
07:15
DavideFitbit
05-04-2022
18:35
07:15
DavideFitbit
I have a Charge 5 and it's stuck on what appears to be the notification screen, but it's just black. It won't swipe to any other screen, and it won't reboot either. Help?
Moderator edit: format
05-04-2022 18:54
05-04-2022 18:54
Mine is stuck with a logo on the screen. I've searched online and none of the suggested solutions work. Hoping someone here or Fitbit support can help as I've only had mine since Christmas.
05-05-2022 12:32
05-05-2022 12:32
05-05-2022 16:40
05-05-2022 16:40
Thank you so much for letting me know you got it to work and how. I'm trying but not successful yet.
How long after the 3rd press did it reboot and how long did it take? Mine blinks black so I think I've had success, but then goes back to the full logo.
I appreciate your help as I haven't heard back from Fitbit yet.
05-05-2022 18:22
05-05-2022 18:22
05-05-2022 18:39
05-05-2022 18:39
You are right, the battery seems to last forever so I haven't tried that yet.
I'm not getting any notifications and when I look at my app on my phone it is t tracking anything at all. I e seen both the black screen and the full screen logo both as very common issues and from what I've seen the solution is the same to both. I will keep trying and hope I can get the timing right like you did.
I feel a buzz every time I press the button and then it buzzes and goes to black about two seconds after the third push. I keep hoping, but so far just right back to full logo.
I guess I may have to break down and call the support line. At this point I'd just like a new Fitbit as mine is only 4 months old and it shouldn't take this much time and energy to fix it.
I do appreciate your time and help. Hopefully persistence will pay off if I keep trying.
05-07-2022
07:14
08:54
05-07-2022
07:14
08:54
Hi, I appreciate all the information that you've shared about this inconvenience with your Charge 5 and the troubleshooting steps that you already tried, @monkeygirlinri @MargieATL.
@MargieATL For this issue you mentioned, it's usually recommended to try the three pulse restart and you can also try changing to a different clock face:
In case that you continue to have the same problem after the restart or if you're not able to complete this procedure, I do recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@monkeygirlinri Thanks for sharing all these updates, it's good to know that your device started working properly again.
See you around.
05-08-2022 16:43
05-08-2022 16:43
This worked for me. I had five dots on screen and could not get out of it. Rebooted as you suggested and it is working fine. Thank so much for the help!
05-12-2022
07:10
08:54
05-12-2022
07:10
08:54
05-12-2022 09:31
05-12-2022 09:31
Hi my fitbit also was stuck on a blank screen about 7 months old. Fitbit eventually replaced it but with a refurbished one not happy with the service from them.smd tried everything to reset nothing worked
05-13-2022
21:19
08:55
05-13-2022
21:19
08:55
Welcome to the Community forums, @Jackieswiss.
I understand your frustration, and hanks again for sharing your feedback and comments about this. I'm sorry to see that it wasn't possible to get a new device. The team is constantly working to improve the Fitbit experience and your feedback is greatly appreciated.
If you have any questions or concerns about the type of replacement you received. I recommend that you continue the communication with the Customer Support team so they can provide you with more information.
See you around.
