11-11-2023
09:50
16:02
11-11-2023
09:50
16:02
My Fitbit five had a red dot white circle around it let the battery die now trying to restart to try to fix it and it won’t charge back up at this time. How do you get out of that problem
Best Answer11-11-2023 16:11
11-11-2023 16:11
Hi there, @Dbljr. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 is stuck on a red X and that it won't charge. Thank you so much for taking the time to troubleshoot the issue with your Fitbit device before reaching out, I'll be glad to continue assisting you.
Sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely, like in your case). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try the restarting your Charge 5. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If you manage to recharge your Charge 5, but it's still stuck on the red X, please try the steps below in the order listed:
Let me know how it goes.
11-11-2023 16:11
