05-12-2023
13:03
06:50
05-12-2023
13:03
06:50
I have an “X” in a red circle on the screen, does anyone know what this indicates. Seems to be frozen!!
08-02-2023 17:18
08-02-2023 17:18
Exactly my experience. I got the email. The option was buy a new one because mine is 1.5 years old and out of warranty. Terrible is right.
08-12-2023 07:51
08-12-2023 07:51
Tried this, didn’t work. When I contacted Fitbit I got an email saying I can’t get a refund repair because I’m not in Europe. I bought the Fitbit in Europe in November 2021. Warranty should be for 2 years no matter where I live. Not happy
08-17-2023 05:30
08-17-2023 05:30
did you get reply from company, i have same problem.
Best Answer08-17-2023 06:25
08-17-2023 06:25
Best Answer08-21-2023 14:27
08-21-2023 14:27
I plugged it into a computer for 30 minutes using a USB cord. I then got a red circle with an x in the middle. Then I plugged it into a wall charger and pushed the small button 3 times ( I felt it vibrate after each push of the button) and it reset. I got a Fitbit logo for a couple of seconds then it changed to the charging screen. I think the watch battery was drained because it was at 3%. It then charged normally.
Best Answer08-22-2023 06:44
08-22-2023 06:44
08-22-2023
19:24
16:22
ManuFitbit
08-22-2023
19:24
16:22
ManuFitbit
Same here 🤬🤬🤬
Time to switch brands.
Yup. Same here.
08-25-2023 22:57
08-25-2023 22:57
My Fitbit Charge 5 has been working perfectly until I was prompted to install the latest firmware update. During the update process, my screen too had the infamous white X inside a red circle. I tried all the suggested methods to reset/restart the device but to no avail. Occasionally the Fitbit logo will appear by flashing on and off, then after a while it goes back to the white X inside the red circle. WTF. I did contact Customer Support and a replacement is on the way. I feel for those who did not get a replacement as this is caused 100% by Fitbit, not the user. Without the firmware update, it works perfectly. They should at least caution you not to update if you don't want the new features and explain the risks associated with updating. Had I known that, I would not have tried updating it. This is not good at all. But at least for me a solution was found with a replacement.
08-26-2023 08:39
08-26-2023 08:39
08-26-2023
08:58
16:07
ManuFitbit
08-26-2023
08:58
16:07
ManuFitbit
Same here and really angry about it!!!
Same and really angry about it
08-26-2023 10:21
08-26-2023 10:21
13:23
15:47
ManuFitbit
08-26-2023
13:23
15:47
ManuFitbit
Did not work and now my Fitbit won’t be found via Bluetooth. Worst advice.
Same for me! I’m very disappointed with their customer service post bought out by Google and can’t believe this an issue from them that they won’t solve for us. Makes me now want to have a Fitbit now.
I tried that! I did get my charging screen very briefly but mine was at 88%. Glad it worked for you!
08-26-2023 20:26
08-26-2023 20:26
08-30-2023
17:12
16:25
ManuFitbit
08-30-2023
17:12
16:25
ManuFitbit
Same here, what the heck is going on? My fitbit charge 5 is ~2 years old as well, and I now have the red X. Fitbits seem to be built horribly.
Google is not a great customer service company, just the opposite.
08-31-2023 09:27
08-31-2023 09:27
09-04-2023 16:01
09-04-2023 16:01
None of those steps worked.
My charge 5 suddenly stopped working. The face occasionally flashes a logo and the app displays a red exclamation mark. It was fully charged and synched minutes earlier. I tried the usual steps, but it is still unresponsive. I suspect a faulty firmware update, but don't know how to correct it.
Best Answer09-06-2023 02:34
09-06-2023 02:34
Hiya Nanafit54
Has this issue been resolved?
I followed the steps but its still there and I can't get hold of anyone to help me out!
Many thanks
Rabster.
Best Answer09-06-2023 02:35
09-06-2023 02:35
Hi Marrefitbit
I followed all the steps recommended but it's not resolved the issue.
Please can you advise?
Many thanks
R
Best Answer09-06-2023 03:22
09-06-2023 03:22
09-06-2023 04:41
09-06-2023 04:41
Thank you - I'm going to send it back.
