04-08-2024
04:14
11:36
04-08-2024
04:14
11:36
Best Answer04-08-2024 06:15
04-08-2024 06:15
Hi, @Fivenotwork, welcome to the community, more information will be helpful, was your Charge 5 previously paired with the Fitbit app on your phone? Which phone are you using? How far did you get when trying to pair with the app? May I suggest you review This video which provides a detailed demonstration of the setup procedure?
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
Best Answer04-10-2024 12:27
04-10-2024 12:27
Hi @Fivenotwork. Welcome to the community forums.
Thank you for sharing the screenshot about this inconvenience.
In addition to the information provided by @Gr4ndp4, I'd suggest try to sync the device with the Fitbit app: From the Today tab, tap the devices icon > Charge 5 > Sync Now.
If that doesn't work, please try to change the clock face: How do I change the clock face on my Fitbit device?
In addition, try to perform a restart.
Thanks @Gr4ndp4 for helping.
