07-14-2024
12:10
10:11
07-14-2024
12:10
10:11
Charge 5 is doing, it again. This is my second unit to replace one from two years ago which was unrecoverable. And where do l find my owner start date for the unit.
Best Answer07-14-2024 13:14
07-14-2024 13:14
Hi, @Ke.steel you can get in touch with Fitbit Customer Support on Contact.fitbit.com to find out the original replacement date. Having said that, unfortunately, if your original Charge 5 is from two years ago, you are unlikely to be covered under the Fitbit Warranty . Nevertheless, it is definitely worth giving them a call - they are often able to offer a significant discount to loyal customers looking to upgrade.
Alternatively, if you post about your current issue someone here on the forums may be able to help you.
Best Answer07-15-2024 23:18
07-15-2024 23:18
