02-19-2023 23:59
02-19-2023 23:59
Hello, I got my charge 5 for 5 days now. So quite new. But today I got a bit concerned. I woke up at 7.18 am, moved about, walked the dogs, etc and when syncing my device it shows I woke up at 7.41 but by 7.20 I read my app and it already recorded that I had done 200 steps. This makes no sense ;( help please?
Best Answer02-20-2023 00:55
02-20-2023 00:55
Hey there, I've had my Charge5 for abt 8 months and noticed the thing with these (any step counter) is it mostly goes off the movement of your arm/body not necessarily steps. So if ya shake your arm in the right way it'll register as steps. I was bouncing a tiny bit on the edge of my bed and watched the steps add up. Sadly the only way you can count actual true steps is to put the d@mn thing on your ankle. So the number of steps ya get at the end of the day is just an estimate, it could be more or less. Just give ya a rough idea. At least that's how it is with mine. So don't be too concerned. Hope that helps! Other thing I've noticed is ya might want to
02-20-2023 00:57
02-20-2023 00:57
Ps, you were probably moving in your sleep or it could have counted any moving you did getting up at night.
Best Answer02-20-2023 01:31
02-20-2023 01:31
Thank you! But I the concern is that I was up at 7.18 am … and it recorded me sleeping until 7.41. Strange ;/
Best Answer02-21-2023 05:25
02-21-2023 05:25
I was mixing/tossing a salad the other day and gained 50 extra steps! Maybe I should have been stepping while tossing to match the Charge 5 inaccuracies! 😂😭 This unit is terribly over sensitive to movement!
Best Answer02-21-2023 05:27
02-21-2023 05:27
Thanks for the ankle option! 😂😭
