06-08-2025 03:11
06-08-2025 03:11
Hi. My charge 5 has died completely after being in water for a short while a few days ago
ive tried charging and also forced restart as per instructions on here
Does anyone have any ideas whether I might be able to get it working again?
Im assuming there is some life in it as there’s a vibration when I connect it to the charger (although this could possibly be the charger vibrating???)
06-08-2025 10:54
06-08-2025 10:54
Hello @Nicd27
By any chance, did you turn on the Water lock feature before going into the water? If so, I learned that it takes very firm, strong tapping to turn off the Water lock feature. I had to take off my Charge 5, put it on the counter, then keep firmly tapping on the display until the Water lock disabled and my clock face appeared.
Best Answer06-12-2025 09:59
06-12-2025 09:59
Thanks for the suggestion RiekoC, but no luck at all with that
think I might be shopping for a new watch!
Best Answer06-12-2025 10:32
06-12-2025 10:32
Hello @Nicd27
Thanks for letting us know that it doesn't seem like the Water lock feature was on. Sorry to see that my suggestion didn't help.
Best Answer06-12-2025 18:50
06-12-2025 18:50
I experienced that. My clock was died, fortunately, it was in guarantee period. So, I claimed it back and got new one.
After that, I nevver use it in the water again.
I don't trust this mode any more. Fitbit is not suit for the water sport. It is not completely designed for that.
Best Answer06-12-2025 19:24 - edited 06-13-2025 21:53
@RiekoC wrote:Hello @Nicd27
The same thing happened to me today. I'm so frustrated. I was only wading in shallow water. I've been trying to restart it for several hours, but no luck. The screen is black and it just pulsates when I attach the charger. Mine isn't in the warranty period, so I'm out of luck. It's very disappointing as I'm in a financial crisis due to being unable to work for over 8 months due to illness. I rely on my fitbit for tracking my sleep, heart rate, etc.
Update* My Charge 5 turned on this morning after seeing it in the counter and pressing really hard on the screen. However, now it won't sync with my Galaxy S22. I select on the APP and it just keeps spinning, never completes syncing and the time is incorrect.
