08-29-2023
14:09
06:42
DavideFitbit
08-29-2023
14:09
06:42
DavideFitbit
Whilst on charge my Fitbit Charge 5 keeps vibrating - very annoying as my charger is in the bedroom so to charge overnight. Is this normal and can I stop it? Didn't happen with my Charge 4. 😕 Anyone else experiencing this? Would appreciate advice. Thanks.
Hi, it's good to see you participating in the community forums, @Gill30.
Thanks for the information you've provided about this inconvenience with your Charge 5.
Let me know if you experience this problem every time that you charge your device or if happened only once. In the meantime, please try completing a three pulse restart using the charging cable and let me know if the issue persists.
In addition, try using a different USB port or a UL-certified wall charger to charge your device.
Thanks for your interest. Did both, as suggested. Think it might have been the port on my charger. Unless I didn't wake, it seems not to have happened since!. Thanks again.
