Charge 5 white screen
ANSWERED
Hi, my charge 5 has stopped working properly. Screen just displays a white. Will no longer sync with fitbit app. Please can you advise?
Thanks
1 BEST ANSWER
Accepted Solutions
Hi there, @HB1980. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
If you haven't done so yet, please restart your Charge 5 as suggested here How do I restart my Fitbit device?
If the restart doesn't work, but it helps with the syncing issue, please now try to change your clock face. If this fixes the issue with the screen, you can change your clock face back to the original clock face.
2 REPLIES 2
Welcome to the Fitbit community, @HB1980!
Sad to hear you're having issues with your Charge 5. As a first attempt to get things fixed I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt, please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
