07-28-2023
04:01
04:14
07-28-2023
04:01
04:14
My Charge 5 was vibrating continuously when on charge. Now it vibrates only for a few seconds every half hour or so. The Fitbit logo shows for a few seconds and then screen goes blank. I've tried all the reboot options and occasionally I do get the red circle with white X but still it does not start or charge even after performing reboot option of pressing charger button 3 times.
Best Answer07-28-2023 04:19
07-28-2023 04:19
Hi there, @badmin381. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
In addition to the steps you've tried, please try the following steps while your Charge 5 is connected to the charging cable:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If the above doesn't work and you don't feel any vibration while performing a restart, please try the steps provided here Why isn't my Fitbit device's battery charging?
Once you make sure that your Charge 5 is charging, try the steps above one more time.
07-28-2023 04:19
