04-27-2024
16:10
05:40
04-27-2024
16:10
05:40
Recently I've noticed my charge 5 not connecting properly to the cable, but after a few tries of connecting and disconnecting it, it would start charging. Today though, I've wiped the sensors on the charging cable and the back of the fitbit and it still won't charge. I've also tried using a different usb port and still won't charge. I did a restart on the fitbit as well and nothing has changed. I can't charge my fitbit. The cable is not damaged or anything.
Best Answer04-28-2024 05:41
04-28-2024 05:41
Hi there, @Miyakojima. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 has stopped charging. I understand where your concern is coming from, we're here to help!
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Thanks in advance!
Best Answer04-28-2024 06:24
04-28-2024 06:24
ive been having the exact same issue in addition to low battery at the end of every day despite being charged at 100% when it does charge. What was the resolution? I have not yet contacted support.
Best Answer04-28-2024 11:49
04-28-2024 11:49
