03-20-2024
16:31
10:42
AndreaFitbit
03-20-2024
16:31
10:42
AndreaFitbit
My Charge 5 won't charge past 1%. At one point it showed the charge percentage as up to 20%, but then dropped back down to 1%. I've moved the charger to a different wall outlet and wiped off both the back of the 5 and the prongs on the charger itself, but it hasn't helped. What should I do next?
Moderator Edit: Formatting.
03-21-2024 10:39
03-21-2024 10:39
Thanks for getting back to us @KGSeifert. I'll be happy to help you with your Charge 5 battery charge. Thank you for mentioning the steps you have followed in order to correct this.
Please confirm that you have tried restarting your tracker with the instructions of: How do I restart my Fitbit device?
03-21-2024 12:03
03-21-2024 12:03
Hello. Yes, I have tried restarting it several times. On the charger it will show fully charged but when I put it on, it will go down to below 10% almost immediately
03-21-2024 12:43
03-21-2024 12:43
I have the same problem. Tried restarting it, but it didn't do anything. What should I do?
03-21-2024 13:11
03-21-2024 13:11
Thanks for getting back to us and for troubleshooting this issue @KGSeifert, welcome @LiisNigul.
Please confirm that you also have checked the advise of help article: Why isn't my Fitbit device's battery charging?
03-21-2024 13:49
03-21-2024 13:49
Yes, I have. I have wiped off the back of the don’t and also the prong side on the charger
03-21-2024 15:49
03-21-2024 15:49
Thanks for getting back to us and for checking the advised troubleshooting steps @KGSeifert.
I went ahead and created a case on your behalf.
Please check your email.
