02-24-2023
19:05
08:12
02-24-2023
19:05
08:12
How to resolve issue on bluetooth connection. Tried all the tips found in forum but still failed 😨
Best Answer02-24-2023 20:31
02-24-2023 20:31
Hi @Mhyr which smartphone or tablet are you using and which operating system? That would help us to know more about your problem. I see you posted in December with this issue - were you able to get it connected since that last post?
Best Answer02-25-2023 07:44
02-25-2023 07:44
Hello I’m using an iOS 16.3.1 at an iphone device. I got connected in December although gets disconnected at bluetooth most of the time which led me to forget device and then add device again. Was able to pair and connected for few days but now couldn’t connect again for almost 2 weeks already.
Best Answer02-25-2023 07:58
02-25-2023 07:58
@Mhyr be sure your app is up to date and get with customer support. They can walk you through it.
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
02-25-2023 08:15 - edited 03-06-2024 04:51
Hi there, @Mhyr. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out. I understand how you must be feeling.
In addition to the steps you've done so far, I'd recommend trying the following in the order listed:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
If the above doesn't work, please follow @Odyssey13's advice and chat with us online or give us a call. Click here to get connected.
02-25-2023 10:05
02-25-2023 10:05
It is beyond belief that these are the steps that must be taken to enable my device to do the most basic and necessary task - syncing data. I hate this device so much. I've spent over an hour doing all the steps before this one and nothing works. I'm about to chuck it in the trash and buy something that does the basics and connects and syncs, ALONG WITH ALL THE OTHER DEVICES I OWN AND WITHOUT DISABLING EVERY SINGLE ONE OF THEM TO GET ONE STUPID DEVICE TO DO ITS JOB.
Best Answer02-25-2023 16:20
02-25-2023 16:20
I’ve done ALL possible solutions you’ve listed. I’ve had different fitbits in the past years but never had this problem. It’s so annoying 😤
