10-23-2024
23:48
06:53
10-23-2024
23:48
06:53
How to connect my Fitbit device to my phone
Best Answer10-24-2024 05:53
10-24-2024 05:53
@Frank8590
Open the Fitbit app on your phone, login, then tap on the battery icon at the top left.
The add device is on that screen. Follow the prompts to add your device.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
10-24-2024 06:56
10-24-2024 06:56
Hi there, @Frank8590. Welcome to the Fitbit Community Forums.
Adding to what @gdio53 has shared with you, I also recommend taking a look at this help article How do I set up my Fitbit device?
On a side note, I'd recommend checking if your mobile device meets the requirements to properly operate with your Fitbit device. For more information, see Fitbit Compatible Devices.
Best Answer10-24-2024 12:35
10-24-2024 12:35
Hello @Frank8590
Were you able to sync your Charge 5 to the Fitbit app on your phone before? Is this a new issue that started recently?
