04-28-2023
17:39
05:20
04-28-2023
17:39
05:20
Fitbit no longer displays ‘fat burning’ or ‘cardio’ while exercising. The app show I was in all zones but charge 5 doesn’t display them like it used to while exercising.
Best Answer04-29-2023 05:29 - edited 03-17-2024 06:24
Hi there, @LAnor. Thanks for the details provided in your post about the issue with your Charge 5.
As a first approach, I'd recommend checking if the heart rate zone notifications are turned on. To do so, follow the steps below:
On your tracker, swipe left or right to the Exercise app, then swipe up to find an exercise.
Tap to choose an exercise, then swipe up through the exercise settings.
Tap Heart Zone Notifications to turn the setting on or off.
If the above is set correctly, please try restarting your Charge 5 by following these steps. Then, please try again and see if the restart made the trick.
Best Answer05-01-2023 08:41
05-01-2023 08:41
Just did that. Don’t know why it was turned off. Thanks
Best Answer05-01-2023 08:46 - edited 03-17-2024 06:03
@LAnor You're very welcome! I'm glad to hear that the issue was solved.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
