05-20-2024
02:24
03:52
05-20-2024
02:24
03:52
Hi All
About 48 hours ago my 5 stopped holding charge, It goes from 100% to dead in half an hour or so. I've restarted in the settings, done a factory reset and also the '3 button push' reset.
Does anyone have a solution please?
Many thanks in advance.
05-20-2024 03:57
05-20-2024 03:57
Hi there, @MartinB123. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Charge 5 is still draining so quickly. I understand your concern, I will do my best to help you with this!
Regarding the battery short life, in general, it is recommended to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
05-20-2024 05:41
05-20-2024 05:41
There is no solution. This has been caused by a firmware update and many other users are experiencing the same issue. Suggestions like @MarreFitbit made below most likely wont work. If you contact tech support they will troubleshoot with you and if your device is out of warranty they will most likely offer 50% off a new device. If it’s in warranty they will prob send you a new Charge 5.
My advice would be look for a different brand entirely or holdout and hope there is a firmware update to fix the issue but I wouldn’t hold your breath.
05-20-2024 06:01
05-20-2024 06:01
05-21-2024 08:06
05-21-2024 08:06
Hi MarreFitbit
Yes, I've clarified but please may I have a sloution?
Thank you in advance
Best Answer05-21-2024 15:39
05-21-2024 15:39
You won't get a better solution besides buying a tracker that the brand stands behind. My husband and I have had the most disappointing experience with our Charge 5s every since Google bought Fitbit.
05-21-2024 16:19
05-21-2024 16:19
No, they don't have a solution.
05-21-2024 23:27
05-21-2024 23:27
I really wish you and the rest of the Fitbit support team here - if you're even real people, which is hard to tell, since you all just parrot the same ineffectual drivel - would stop treating your customers like idiots. Take responsibility for a change and own up to the fact that you broke things. Stop trying to blame the customer.
05-25-2024 15:22
05-25-2024 15:22
Hello @MartinB123
When my Charge 5 started having rapid battery drain, I restarted and recharged my device multiple times over several days. As soon as I noticed the battery% had a big drop, I restarted and put my Fitbit on the charger, often doing this multiple times in a day. This process eventually got my Charge 5 "unstuck" and the battery life went back to lasting 6-7 days. Although there's no guarantee that this will work, it might be worth a try.
05-26-2024 07:52
05-26-2024 07:52
Thanks! Will try that!
Best Answer05-26-2024 13:20
05-26-2024 13:20
Mine is doing the same thing. Just all of the sudden. Have you had any luck on warranty? I have not.
Best Answer05-26-2024 13:37
05-26-2024 13:37
I will try anything at this point, looks like warranty is out of the question. I purchased mine at Kohl's and their return policy is 30-days! And I cannot even get ahold of anyone from Fitbit!! Thank you.
Best Answer06-03-2024 15:43
06-03-2024 15:43
WOW! Mine is less than a year!! Oct. 19,2023...
