08-02-2023
21:42
03:41
08-02-2023
21:42
03:41
My charge 5 was showing the wrong time and date so I reset it and it still didn't work. I then deleted it from my device profile on the app and now the app will not work properly. It will not add the device back and just says thatbit cannot sync even though the screen pops up and says it's been found. I have done every it as instructed me to do and nothing works. Now my charge 5 is useless at the moment because it doesn't have the right date or time. Anyone else having this problem. I think it's an app issue but idk. I'm running on android 13 with a galaxy s20 fe 5g.
Best Answer08-07-2023 13:35
08-07-2023 13:35
You're right, it is an app issue. There's a few things you can do:
1.) Clear the app cache
2.) Delete the app and then reinstall it
3.) Set the device up again during an off-time
4.) Reboot your phone
5.) Turn off or move ANY BTs in the area
one cruise ship at a time!08-08-2023 03:47
08-08-2023 03:47
Hi there, @Nicole6265. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
Are you still having issues adding your Charge 5 with your phone? If so, please try the steps recommended by @DramaQueenDiva. If the issue persists, I suggest trying the steps below:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer08-08-2023 03:51
08-08-2023 03:51
Thanks, everyone. I got it back working. I restarted my phone and fitbit at the same time as well as deleted the app and reinstalled it and it now works fine.
08-08-2023 03:57
08-08-2023 03:57
@Nicole6265 Awesome! I'm glad to hear you managed to solve the issue. Thanks for sharing the steps that worked for you.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
