01-28-2024
07:52
09:17
01-28-2024
07:52
09:17
Fit bit charge 5 dead
Not responding
If I press the reset button at the charger, a vibration is felt. But screen is absolutely dead.
No Fitbit logo. Not lights. Tapping on screen no response
Best Answer01-28-2024 09:24 - edited 01-28-2024 09:25
Hi there, @Kifee. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 is not responding to anything.
Since your Charge 5 has vibrated when you attempted to perform a restart, would you mind checking whether it's syncing with the Fitbit app? Even if the screen is blank, you can try syncing and see if the synchronization takes place. Try manually syncing by going to the Today tab on the Fitbit app, tap Devices > device image and tap Sync Now.
If the above doesn't work, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work, please try the following:
