Charge 5 won't stay connected to charger
My charge will not stay connected to charge.  Any small movement disconnects the watch from charger
2 REPLIES 2
Hello @Jlm344 Welcome to the Fitbit Community! It's great to have you here!
Thank you for letting us know that your Fitbit disconnects from the charging cable with any small movement. I'm happy to help you.
To learn more about how to connect your Fitbit to the charging cable, you can consult the following help article: How do I charge my Fitbit device?
You only need to select your Fitbit model and follow the steps outlined in the article.
Hello @Jlm344
It is a bit tricky to connect your Charge 5 to the charging cable. As you noted, it doesn't take much to disconnect the Charge 5 from the charging puck.
What works for me is putting my Charge 5 on its side, connect it to the charging puck, then carefully tap the display to make sure that it's charging.
