10-14-2023
15:09
16:16
10-14-2023
15:09
16:16
Called Fitbit Support to learn how to generate Recovery Codes. Fitbit is having server errors.
Went to open the app and it says it is not linked to my Charge 5. Under Bluetooth Pairing and Linking, it just keeps saying, "There was an error while trying to bluetooth pair to your device. Would you like to try again?" I click the [ Try again ] button. Groundhog Day.
10-14-2023 16:39
10-14-2023 16:39
Maria,
That was for a separate issue—Disabling 2FA is hosed due to Fitbit servers being flakey.
I haven't contacted Fitbit support about the lack of ability to sync due to Bluetooth and Linking not working... Should I?
Drew
10-14-2023 16:22
10-14-2023 16:22
Hi there, @Drew5316. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issues with your Charge 5 before reaching out. W
If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance. Since you have reported this matter to our Support Team, please note there's nothing left we here in the community can suggest other than reaching out to our team again. Nevertheless, I've seen they advised you to contact them within 24-48 hours.
Best Answer10-14-2023 16:39
10-14-2023 16:39
Maria,
Drew
10-15-2023 00:47
10-15-2023 00:47
Exactly like mine 😞 And it definitely is not syncing properly 😞 Might be looking for a new brand I think - my charge 5 is only 5 months old, and was sent as a warranty replacemnt when my Charge 4 died 😞
Best Answer10-15-2023 14:27
10-15-2023 14:27
So ,what's the answer, I am having the same issue, how do you fit it and pair the charge 5 to Bluetooth, now it doesn't even show up, when Bluetooth searches.
10-15-2023 15:11
10-15-2023 15:11
😞 To get my bluetooth to find it, I have to shut bluetooth down, then restart the phone and my charge 5 - someone else suggested it, I tried it - but it only works for a little while - and still wont pair it 😞
Best Answer10-15-2023 15:53
10-15-2023 15:53
10-15-2023 16:16
10-15-2023 16:16
😞 Tried that - and it found it, but still wouldnt pair it! Might give it another go later - but am becoming pretty discouraged 😞
Best Answer10-16-2023 15:51
10-16-2023 15:51
I've read a few posts that mention the user had to turn Wi-Fi off, then on again to get their device to sync. It might be worth trying this to see if it helps with the sync issue.
10-16-2023 17:06
10-16-2023 17:06
:'( Tried that - it is syncing sometimes now - but still wont pair to my phone. I disconnected all of my bluetooth devices - everything else works properly, except for my fitbit 😞
Best Answer10-16-2023 17:24
10-16-2023 17:24
10-16-2023 23:40
10-16-2023 23:40
It is really strange - sometimes it is there, others it doesnt show up - but when I try to pair it, it always says there is an error :'( Thank you so much for trying to help - I will keep trying 🙂 ❤️
Best Answer10-17-2023 06:10
10-17-2023 06:10
