Charge 5 won't sync anymore
ANSWERED
Fitbit not syncing despite being fully charge, also have removed app and replaced, turned off Bluetooth and out it back on - can anyone help? Always been issues with the charge 5. It’s been replaced 3 times in 2 years!
1 BEST ANSWER
Accepted Solutions
Hi there, @Veronica1976. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
  • Unpair your Charge 5 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Charge 5.
  • If there is no connection, restart your Charge 5.
  • Once your Charge 5 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
1 REPLY 1
