02-27-2023
01:10
04:34
02-27-2023
01:10
04:34
Hello I had my Charge 4 replaced recently with a Charge 5. Despite following all the tips in the forum it still doesn't sync so I have to disconnect the Bluetooth on my iPhone every time. I've shut down everything and reinstalled but same problem. The Charge 4 didn't have a sync issue! Any ideas
Thanks in advance
Best Answer02-27-2023 04:37
02-27-2023 04:37
Hi there, @FMQ. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your new Charge 5 before reaching out.
While reading your posts above, I was wondering if you did remove your old Charge 4 from your Fitbit account and phone's Bluetooth settings?
It seems that your Charge 5 cannot connect properly to your Fitbit app since you haven't yet forgotten the connection between your old Charge 4 and the phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
02-27-2023 04:37
Best Answer03-03-2023 03:30
03-03-2023 03:30
So I had done most of the above but it turned out that another app on Bluetooth needed to be removed & my Fitbit started syncing straight away. Thanks so much for the info
03-03-2023 04:10 - edited 07-29-2023 04:10
@FMQ Awesome! I'm glad to hear you were able to solve the issue.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
