03-05-2024
07:26
09:12
03-05-2024
07:26
09:12
I have to pull down app screen to update 4 or 5 times to get a complete synch. Often the synch just quits. Sometimes it updates sleep score or battery charge, but not steps. Sometimes other data. Eventually everything synchs. Is this an app glitch or what?
Hi there, @Kpfeil. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Charge 5 is not syncing properly, I understand where your concern is coming from. I'll do my best to get you back on track.
As a first approach, I suggest following the troubleshooting steps provided in this help article Why won't my Fitbit device sync?
If the issue persists, please try the steps below in the order listed:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Please be aware that most Fitbit devices store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data. Summary data (calories, distance, steps, and floors) will be stored for 30 days. Nevertheless, if your Fitbit device was unpaired from your Fitbit account during this period of time, neither the 7 days can be recovered or restored.
Best AnswerGet used to it. Ever since the change to V4, sync has gotten less reliable. Even if it looks like it synced, click in the upper left corner on the device and I bet it still shows syncing. I’ve rebooted, turned Bluetooth off/on powered off, stuck my left hand up and spun in a circle counterclockwise and some it works, sometimes it doesn’t. This is on IOS, I can’t say anything for Android.
Best AnswerHello @Kpfeil and @SunsetRunner
I've noticed that the sync issue seems to affect iOS users more than Android users based on recent posts. I'm an Android user and don't have too much issue with syncing.
When I do experience a sync issue, I found that turning off Bluetooth, then turning it back on usually is successful in getting the app to sync. Another way to do this is to turn on Airplane mode, then turn it off. Although there's no guarantee that you will have the same positive result, it might be worth a try.
