06-05-2023 01:34
06-05-2023 01:34
After swimming in the sea, my charge 5 wouldn't turn on. After charging it it turned on but had a blank screen. I eventuality got it to turn on and the screen to work (after a supposed firmware update). Now it turns on and connects to my app but the battery drainsfrom a full charge to 0 within two hours and the lights that track the steps (etc) are not on and out isn't tracking. Basically it's just want old watch now.
I have already restarted a dozen times using the cord button.
I have already restarted using the restart in the phone.
I have twice cleared the data and reconnected to my phone.
I have checked for updates.
Nothing is working.
Please don't tell me to restart the watch again, as again I've already done that.
Is there a way to force a reinstalation of the firmware?
Best Answer06-05-2023 02:27
06-05-2023 02:27
Hi, @JStein77, welcome to the community, swimming in the sea should not have resulted in this problem subject to your device remaining damage free. Noting the steps you have taken I think your best next step is to talk to "Customer Support" using the chat facility or phone for a prompt response. Before you make the call make notes of the steps you have taken along with the results. You do not mention when & where you bought your device, will you benefit from Fitbit's "warranty" ?
I hope this helps.
Cheers
Gr4ndp4 | UK
06-05-2023 02:27
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer06-05-2023 03:21
06-05-2023 03:21
06-05-2023 03:41
06-05-2023 03:41
Hi, @JStein77, I'm pleased you sorted it out. There is an option for you to mark my post as "Best Answer" if you feel it merits it.
Cheers
Gr4ndp4 | UK
