10-07-2023
03:54
04:14
10-07-2023
03:54
04:14
I upgraded a month ago from charge 2 to 5 to track my swimming. I had to restart the charge5 because it stopped collecting HR data for 2 hours the other day! Then this morning I woke up and it showed 1.5 hours of sleep. I pay for premium to get sleep stats! I quit the app several times and restarted the charge. When I restart, I use the restart on the charge screen itself, I don’t see any external button to press, as I have seen referenced in some discussions.
IS THE PROBLEM WITH THE APP OR THE DEVICE.
This charge 5 has great features but it doesn’t work as well as the charge 2. I'd hate to change trackers again…
Best Answer10-07-2023 04:16 - edited 10-07-2023 05:29
Hi there, @Emjayv. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. I understand how you must be feeling.
To better assist you, I'd like to know if your sleep data is the only information you're missing? Is your Charge 5 syncing fine with the Fitbit app? Are your steps, calories, distance, etc. transferring to your Fitbit account?
If you're missing just your sleep data, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
Best Answer10-07-2023 04:31
10-07-2023 04:31
Hi Marre! Thanks for quick answer. I have tightened my tracker one notch, maybe that will help.
BR, HRV and skin temp are unavailable, I guess because sleep data wasn’t collected. Everything else is syncing,
App shows that heart rate was recorded, Beats per Minute, through the night, but no sleep stats. I don’t get it
I’m trying to monitor my resting heart rate, a very important stat for me.
Best Answer10-07-2023 05:37
10-07-2023 05:37
@Emjayv I understand how important the heart rate data is for you.
In addition to the suggestions I've provided above, please try the following:
Best Answer10-07-2023 06:02
10-07-2023 06:02
Thanks, I did all that.
my wrist is very small, perhaps this causes weird results sometimes. We’ll see what tomorrow brings. Thanks
Best Answer10-22-2023 12:06
10-22-2023 12:06
Hi...none of these work as a permanent solution. Seems to me the app started freezing and not recording all my sleep shortly after the update to the app came out. It's obvious this is a problem by the number of complaints rec'd. When will you do to fix this issue?
Bruce Jamieson
