06-30-2022
17:41
10:49
AndreaFitbit
06-30-2022
17:41
10:49
AndreaFitbit
No way to take this down. No turning back now. No way to save my dignity.
Moderator Edit: updated subject for clarity.
Best Answer06-30-2022 23:08
06-30-2022 23:08
Hi @BJDTien since the Fitbit is a wrist based device, it relies on our arms swinging, but when you're on a treadmill, why not put it in a pocket or down your sock? It might be able to capture the steps more accurately for you.
07-01-2022 10:17
07-01-2022 20:13
07-01-2022 20:13
Hello @BJDTien
I wear this on ankle and it will fit on your Charge 5 as well: https://www.amazon.com/Adjustable-Elastic-Compatible-Fitness-Stretchy/dp/B09NMGBJPQ/ref=sr_1_3?crid=...
😉 Super easy to take on and off. That way every step on the treadmill will count for you.
07-05-2022 06:18
07-05-2022 06:18
😄 Hey, thanks! I got myself a lanyard, but I'm deffo gonna look into that!!!
Best Answer07-05-2022 06:29
07-05-2022 06:29
Hello ag @BJDTien
I’m confused about your question being edited as I can only see your original question above. I understood your question perfectly as I’ve had multiple back surgeries that required me to hold the bars of my treadmill because of balance issues in the past. I recommend ankle straps because they worked great for me. I’ve never tried a lanyard before. I hope it works out for you and gives you the step count you deserve despite having to hold the treadmill bars. 😃 Your stepping so it should definitely count. Enjoy the rest of your week and Happy Stepping!
07-06-2022 19:14
07-06-2022 19:14
20:52
05:47
07-06-2022
20:52
05:47
@BJDTien - was your original description "Track steps while holding treadmill bars"?
And you wanted it to be a suggestion to improve the device the best place for that post is in the feature suggestions forum.
Even so, the suggestions by @SunsetRunner seems like a good suggestion which works also for spinning (indoor biking).
