01-16-2025
01:26
02:46
01-16-2025
01:26
02:46
My Fitbit charge 5 got wet and I put it in uncooked rice to dry it for 2 days, then when I plugged it in to the charger it started vibrating without turning on, what's the problem?
Best Answer01-16-2025 02:49
01-16-2025 02:49
Hi there, @TahaniD. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is not turning on. I understand your concern, I will do my best to help you with this!
If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, please restart your Charge 5 by following these steps.
If the above doesn't work, please try the following:
01-16-2025 02:49
