07-29-2024
11:40
08:46
07-29-2024
11:40
08:46
I jumped in the pool briefly on Saturday and my device stopped working. It also showed low battery. I took it off and now it won’t turn on. I don’t have a button on my USB charger. This is the second time this has happened in 3 weeks. How can I get my device started again?
Best Answer07-29-2024 14:12
07-29-2024 14:12
Hello @RandallStevens
There should be a small inset button on the USB end of the charging cable that came with your device. This article has a picture of it: How do I restart my Charge 5 (<-- click link)
By any chance, did you turn on Water lock on your Charge 5 before you went into the pool? If so, your device might still have Water lock turned on. I found that it takes very firm tapping to turn off Water lock.
Best Answer07-31-2024 08:51
07-31-2024 08:51
Hi there, @RandallStevens. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Charge 5 has stopped working after getting wet. I understand your concern, we're here to help you!
Have you tried what @RiekoC recommended? If your device got wet, it’s important to take it off and dry it well before putting it back on. On the other hand, if your device has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser and dry it with a lint free-cloth.
If you've done the above but to no avail, may I know if your Charge 5 vibrated during the restart process? If it didn't, I'd recommend trying the steps below:
Nevertheless, I've seen you contacted our Support Team after posting here and they already offered some troubleshooting steps, my best advice is to keep the conversation directly with them so they will tell you what is the next step in case that the recommendations provided haven't worked.
Thanks in advance!
Best Answer08-02-2024 10:54
08-02-2024 10:54
It vibrates when I connect it. Please let me know what to do next. Please note I do not have a reset button on my charger
Best Answer08-02-2024 11:14
08-02-2024 11:14
Best Answer08-02-2024 12:04
08-02-2024 12:04
I do not have that button. I do have a charge however. Any idea how to reset without the button?
Best Answer08-02-2024 12:05
08-02-2024 12:05
I contacted the support team and they cannot help me because my charger does not have a reset button. What are my options now?
08-02-2024 17:26
08-02-2024 17:26
I’m also having the exact same issue!!
Currently have it plugged in and it won’t stop vibrating.
Accidentally got into shower with but did have water protection mode on, dried off immediately, then started to vibrate right after on and off. After that got red circle outline with white x inside and this continued to stay on until battery ran out.
Now plug in and won’t stop vibrating and flashing Fitbit logo
Not sure what to do next???
