11-13-2025
10:04
03:30
11-13-2025
10:04
03:30
Hi , my charge 5 won't stay on even when charged , I've connected it to charger and can turn it on like that but it won't stay on , I can't tap it to wake up
11-14-2025 03:35
11-14-2025 03:35
Hi there, @Doonaq. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is not turning on unless it's connected to the charger. I understand your concern, I will do my best to help you with this!
If you haven't done so yet, I'd recommend trying the following steps in the order listed:
Best Answer11-14-2025 04:26
11-14-2025 04:26
I have the same issue: the battery drops from 100% to 0% within one day without any changes to settings (no GPS, display off, etc.). Do I understand correctly that performing a restart by lifting and reconnecting three times should resolve the problem?
Best Answer11-14-2025 07:38 - edited 11-14-2025 07:39
Hi there, @SGCH. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Charge 5 is draining quickly.
Before performing a restart, I'd recommend making sure that your phone's software version is updated. For more information, refer to Check & update your Android version or Update your iPhone or iPad
If you haven't done so yet, please try all tips and recommendations provided here Can I extend my Fitbit device's battery life?
Best Answer11-14-2025 07:39
11-14-2025 07:39
Best Answer11-14-2025 13:18
11-14-2025 13:18
All updated, settings on Charge 5 were not changed. It dies out and cannot be switched on until plugged in. Then it shows that it’s actually charged. I think it’s a different kind of trouble than just low battery. How can I get it fixed?!
Best Answer11-14-2025 16:21
11-14-2025 16:21
Well, here we go again. A minute ago shows 77% and now boom! , cannot be connected to the app, dark screen. The only way to reanimate it -> connect to the charger.
Best Answer11-18-2025 03:35 - edited 11-18-2025 03:35
@Doonaq Thanks for getting back and for the details provided in your last post. I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Hi there, @SGCH. It's nice to see you around the Fitbit Community Forums. Thanks for the details provided in your post about your Charge 5's behavior.
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
