09-23-2021 14:54
09-23-2021 14:54
I just got my Charge 5 today. As soon as I connect to Fitbit app on iPhone, it tells me to update firmware. I started the update but it always stops halfway. I tried different Wi-Fi, restarting Charge 5, restarting my phone, but nothing works. Does anyone know how to fix this?
09-25-2021 18:46
09-25-2021 18:46
Update: I used another iPhone today and it updated in a flash.
Possible reasons:
-Bluetooth on my iPhone doesn't work too well. I've broken my phone several times and sent it to a cheap repair place. Maybe they didn't do a good job.
-Fitbit update doesn't work for all phones. Might be a bug they need to fix.
09-24-2021 10:15
09-24-2021 10:15
@SunsetRunner Welcome to the Fitbit Community. Thanks for the details mentioned.
Let's try the following troubleshooting if you're still experiencing difficulties:
- Force quit the Fitbit app
- Restart your phone once again
- Log into your Fitbit account on a different device, and retry the update
Hope this helps.
09-24-2021 11:22
09-24-2021 11:22
It just took me 3 goes at this but this worked in the end I have iPhone
fully close Fitbit app go to settings put in airplane mode count to ten then turn back on go to Bluetooth and forget device then keep your phone within 3cm of your phone touching worked for me your charge 5 will auto reconnect restart the Fitbit app just sync not update then after sync has completed then try updating firmware again should work be warned mine took about 35 minutes
09-24-2021 12:53
09-24-2021 12:53
Yes I too am having the same issue. I have tried all the trouble shooting methods and nothing has worked. The update gets about 75% through and then just disconnects.
I also cannot change the clock face as the install button is greyed out, and! the magnet for the charger does not seem very strong, drops off as soon as i pick it up ☹️
09-25-2021 08:16
09-25-2021 08:16
I’m having the same problem! Tbh I’m getting massively naffed off with Fitbit! This charge 5 was their last chance with me! I was perfectly happy with my charge 4 till an update made the screen invisible unless in a dark room! I thought I’d give them another chance as I love the features but can’t even get the charge 5 to update!!! It’s very close to going back in its box and being sent back and the charge 4 in the bin and me over to garmin or Apple for a watch!!
09-25-2021 18:46
09-25-2021 18:46
Possible reasons:
09-25-2021 18:55
09-25-2021 18:55
Yeah I didn't quite trust Fitbit either. I had a versa once which just won't charge/turn on after a year. I've been using garmin because their running watch I bought in high school still works till this day. I'm only giving charge 5 a chance because of ECG feature.
09-26-2021 00:13
09-26-2021 00:13
I finally got mine to update by sitting still with my phone in right hand and Fitbit in the other millimetres apart (wouldn’t work other way round)
11-03-2021 16:41
11-03-2021 16:41
Same here. How frustrating. Nothing works. Cannot update this brand new charge 5
11-03-2021 17:12
11-03-2021 17:12
I don't have another iPhone so what do I do?
12-06-2022 10:00
12-06-2022 10:00
I went through the same thing, finally got to talk to a live person at Fitbit, after trying the proposed solutions they mailed me another one at no charge that updated with no problem.
