07-13-2023
02:37
08:45
07-13-2023
02:37
08:45
I cant seem to figure out how to get my fitbit charge 5 to vibrate when i get a phone call or text message.
Best Answer07-13-2023 08:47
07-13-2023 08:47
Hi there, @wabbit8625. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
If you haven't done so yet, I'd recommend following the tips and recommendations provided in this help article Why didn't my Fitbit device alert me?
Best Answer07-14-2023 20:10
07-14-2023 20:10
All of that is not on. I get the get your arse moving notification. I get notifications that someone calls, but no vibration
Best Answer07-14-2023 20:14
07-14-2023 20:14
Might I add this is a brand new fitbit
Best Answer07-16-2023 12:34
07-16-2023 12:34
Hello & welcome @wabbit8625
Sorry to see you're having problems with the notification vibration on your Charge 5.
A couple of suggestions:
You can make the vibrations stronger from the Settings menu on your Charge 5. Swipe down from the clock face to get to the Settings tile (last one) and tap on it. Swipe up to get to Vibrations. Tap to change from Normal to Strong.
Confirm that Calls & the correct text app are selected in the Fitbit app for your Charge 5 notifications, especially if you use more than 1 app for text/IM. To check:
Best Answer07-18-2023 12:07
07-18-2023 12:07
