06-04-2023
03:28
04:37
06-04-2023
03:28
04:37
After charging to 99% it died as soon as I took it off the charger. I charged it again and the same thing happened. Any ideas?
Best Answer06-04-2023 05:02 - edited 06-04-2023 05:03
Hi there, @CityGypsy. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
Please follow the tips and recommendations provided in this help article Why isn't my Fitbit device's battery charging? Let's try making sure both, your Charge 5 and charge and clean and free of any debris.
Best Answer06-04-2023 05:04
06-04-2023 05:04
Hi, @CityGypsy welcome to the community, you say your "Charge 5" "Died" but do not tell us what you saw. If the screen went dark but the Fitbit app synced & indicates it is fully charged, you should try restarting your "Charge 5", this video demonstrates the process.
If the Fitbit app indicates it synced but the SOC dived to 0% on disconnection you should talk to "Customer Support" using the Chat facility or phone for a prompt response. In preparation for your call note the steps you've taken & the results so you can brief the agent, also note when & where you bought your "Charge 5" as you may be able to benefit from Fitbit's warranty. If it is a recent purchase you may alternatively benefit from the retailer's returns policy.
I hope this helps.
Cheers
Gr4ndp4 | UK
06-04-2023 05:45
06-04-2023 05:45
Yes, it was connected to the charging cable.
Best Answer06-04-2023 05:49
06-04-2023 05:49
Hi, @CityGypsy , have you tried the "Restart" procedure? if so let us know how you got on.
Cheers
Gr4ndp4 | UK
Best Answer06-04-2023 06:24
06-04-2023 06:24
No, how do I restart it without having access to the screen?
Best Answer06-04-2023 07:20
06-04-2023 07:20
Hi, @CityGypsy , check out my post about 3 hours ago, there's a link to the video that demonstrates the process.
Let us know how you get on.
Cheers
Cheers
Gr4ndp4 | UK
