03-12-2024
11:06
11:31
03-12-2024
11:06
11:31
Charge 5 goes blank although there is over 60% battery charge. Screen wakes as soon as I connect Fitbit to power outlet
03-13-2024 04:16
03-13-2024 04:16
Welcome to the Fitbit community, @somamudaly!
Sad to hear you're having issues with your Charge 5.
As a first approach to hopefully get things fixed, you should try restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 5 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 5. So, before throwing the towel, please give it another try.
If that won't work for you, I'd suggest letting the battery of your Charge 5 drain to the point where it will shut down. Then give it a full charge and see if it will be back to working order.
I'll keep my fingers crossed.
